Re: Leaded gasoline
Trent Williams
07-28-2002 14:47:57
The guy that worked on my head said, "I'll put hardened seats in it so you can run unleaded" ???
Diesel Don
07-28-2002 19:55:01
 Re: Re: Leaded gasoline in reply to Trent Williams, 07-28-2002 14:47:57
I just had the head done for my '34 Chev truck.There was a crack through #2 exhaust valve seat and after the crack was repaired,they needed to install an insert in that position.The shop and I decided to do them all because once the machine is set up,it is simple to move on and do them all.Had I not needed to do the welding job,I would have run with the original seats.I haven't had any problems with any old engines I run on unleaded fuel.In the case of my old truck,it was cheap insurance because parts are very difficult to find for it.
