Re: 1950 WD Hand Clutch
JMS/MN
07-27-2002 22:16:52
There is an adjustment on the hand clutch- remove the battery box, remove the cover beneath it. There are three sets of shims on the clutch assembly beneath the cover. Remove equal number of shims from each position to tighten up the clutch if necessary. Engaging the clutch will produce a more positive snap than disengaging it. Over center simply means that when you pull the lever towards you, the linkage snaps over its fulcrum,(pivot point) to lock it into place, and it takes more pressure to release it, than to engage it. That's why you hear and feel more snap to push the clutch forward than when you pull it back, and engage it.
