Re: Allis C mag
Diesel Don
07-27-2002 19:48:36
Sounds like you converted to 12v.If you don't get the starter rewound it will probably spin too fast for the impulse coupling to do it's job.If you stay with 6v,there is a problem with the starter.If you mean the starter turns but won't crank the engine,it needs a new drive.If it won't run at all,the contacts may be bad in the switch.
