Company Logo (800) 853-2651 Shop Now
Re: WD-45 Stuck in 4th and nowhere to go!
David T (MO)
07-25-2002 06:22:09
Welcome to the WD line of infamous shifter blues. The stick has jumped out of the forks. Its an easy fix that with a little practice can be done in under five miutes. Pull the rubber boot off the stick and remove the snap ring holding the stick in. Carefully remove the stick watching out that the pivot pins on the sides of the large ball don't fall into the column. With the stick out, use a large screwdriver and move the forks back to the neutral position. Insert the stick, again being careful not to drop the pivot pins down the column, and place the retaining cap over the top of the large ball. Before replacing the snap ring and boot you should try to shim out any up and down play in the stick which seems to contribute to the problem (this seems to have cured it entirely on my WD45). With it fully assembled you should be back in business. Shift slowly and deliberatly while pushing the stick into the column should also help prevent a repeat.
Good luck!
Gary U
07-25-2002 11:20:08
 Re: Re: WD-45 Stuck in 4th and nowhere to go! in reply to David T (MO), 07-25-2002 06:22:09
Thanks so much!
I'm heading out the door right now to take a look at it.
Gary
Today's Featured Article - Dad's Old Silver King and Joe Capalco - by Woody E. Diehl. My father, Charles Diehl, grew up in the Elsworth, Ohio area during the Depression on a small working farm. I never saw the place, nor was I around during his early years. What I know about those hard times comes from listening to Dad and his old pals reminisce from time to time. One of the old timers that would sit with Dad and chew the fat about the 'good ole days' was Joe Capalco. Joe wasn't like most of my Dad's friends. He rarely worked that we knew of. Always had plenty of time ... [Read Article]
Latest Ad: 1950 john deere B straight 6 speed with mid mount cycle bar mower.All orignal paint straight metal. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
