Re: WD45 restoration to a working tractor
JMS/MN
07-24-2002 00:24:23
You should be able to remove the grille by removing the two 1/2" radiator bolts inside the channel frame- need a 3/4 inch socket, and a swivel socket adapter is handy. Reach inside the channel frame from underneath to locate the two bolts. Also need to remove the front bolt on the generator/alternator? Maybe a bolt on the right side of the radiator that holds the curved sheet metal? This normally comes off with radiator removal, but you could remove these parts, and then rebolt the radiator with the two 1/2 inch bolts in the channel frame. The hose can be replaced without removing the water pump. There is no reason to remove the pump, just to replace the hose. Loosen the hose clamps, break the seal of the hose to the radiator and the pump with a screwdriver, and twist it away from both parts. As far as painting- spray cans do not do a good job, but if you just want to stop rust, they might be ok.
