Re: Clunk in reverse gear on 7000
Craig MO
07-15-2002 18:59:20
You have probably chipped or broken reverse idle gear tooth. You can check this by pulling top transmission cover put trans. in second gear before pulling. If it is reverse idler gear remove top plate off rear end housing and you can reach up front and pull reverse idler shaft out of the back and replace reverse idler gear.
