Re: WD45 Questions
David T (MO)
07-15-2002 13:46:29
Does she clatter badly when you try to lift or does nothing at all happen? Normally the cylinders are retracted (down) when not in use so I'm not sure how they could "freeze up". Sure, they can rust up if the hydraulic oil is full of water or the cylinders can rust up if they are left extended (up), but I'm going to guess that either the pump's unloading valve is broken and the poor thing can't lift a kitten (nothing at all happens) or its so full of mud it's unloading as soon as you put lift to her (clatters badly).
