Company Logo (800) 853-2651 Shop Now
Re: Neighbor's AC B engine number
DanD.
07-15-2002 11:46:53
I'll bet if you look a little harder, you'll see that the engine serial number begins with BE not EE. The earlier B's (like yours) used the model BE engine (116 CID) while newer ones used a model CE engine (125 CID). The only difference is a thinner sleeve and bigger piston in the newer ones to get the larger displacement. Any of the older ones that were overhauled almost always got the bigger pistons. Also, I think you misread the serial number page. Serial number 57,342 would have been built in 1942. Finally, I would say that the engine in the tractor is probably the original. It's slightly higher than the tractor serial number which makes sense when you consider that some of the engines were used as power units, on combines, etc., etc. Also, the K suffix would indicate that this engine was originally equipped to burn kerosene or distillate. The main differences would have been lower compression pistons and a different manifold to heat up the incoming air/fuel mixture. This tractor must have the regular fuel tank and then a smaller one for gasoline for starting.
Dennis 9N/2N
07-15-2002 20:12:05
 Re: Re: Neighbor's AC B engine number in reply to DanD., 07-15-2002 11:46:53
Dan, you are right, I did misread the serial number list.
Thanks for the insight into the different displacements. I will recheck the engine number tomorrow (it is my neighbor's tractor and is at his house).
The neighbor did say the man he got it from told him it was originally set up for kerosene.
Today's Featured Article - The History of Old Abe - by Staff. The Case Eagle - Old Abe - is a well known industrial trade-mark throughout the main streets and countryside's of thousands of cities and hamlets in the United States and civilized countries the world over. King of the air, the eagle is an established symbol in American life and heritage. The Case Eagle Old Abe is far more than merely a trademark. He is a character out of history, a bird with a personality and a story all his own. The story begins in the early spring of 1861. In the wild nor ... [Read Article]
Latest Ad: WANTED Rumely Oil Pull Models W X or M [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
