Re: B hydraulic pump
Mike
07-11-2002 17:36:55
Assuming that the fluid doesn't "thin" out when hot and leak out a worn seal, you may want to look for water in the lines. As the water/fluid heats up, the water can turn to steam with a different compressibilty coefficient than the fluid - hence you get partial lift. Just a few thoughts.
George
07-16-2002 11:54:17
 Re: Re: B hydraulic pump in reply to Mike, 07-11-2002 17:36:55
Your Model BAC Tractor Pump is either worn or the Hold Valve is hanging in an open position letting the hydraulic pressure leak back into the system. If you are using the 20 or 30 weight oil, I believe that AC recommended when this tractor was new, you could try a 60 weight nondetergent oil in your system -- this would allow the pump to build more pressure through the thicker oil. If the Hold pressure plunger is sticking, you will have to remove the pump -- but you can also try a can of STP or other oil treatment that would maybe free up the plunger(just add treatment to your hydraulic oil). These pumps can be very tempermental.
Good Luck !!
George
markp
07-14-2002 09:48:57
I'll check it when I work on it next week
steve
07-11-2002 19:19:52
or the fluid is getting air bubbles in it, airation. what type of fluid are you using. I agree with Mike, my first thought would be to drain all three plugs on the bottom, see what comes out, then refill with hytrans fluid (about 2 gallons) buy at Wal Mart for $10.
