Company Logo (800) 853-2651 Shop Now
Re: steering gear box
steve
07-08-2002 20:35:30
ralph, others may give you a place to look for a new box. i can tell you that i "welded" a new follower on mine. i think someone sells them, you drill out and weld in new. what i did was build up a layer with 9018 stick rod, then another pass, then another, etc. after it was 1/2 inch round and 3/4 inch tall, i started to shape it with a small 3 inch cutoff wheel and do-more grinder. i test fit it several times in the slot. it is kind of a tapered dowel. I washed and cleaned my bearing. seal was not much good. I drained out the oil and packed it with grease like a wheel bearing on a car. Reassembled and ben running like that for about a year, no problems. If you cant weld, a weld shop might be able to build it up. The grinding is not hard, just time consuming.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: John Deere Tires And Rims, (1) Set Of Duals, Axle Mounting Hubs, Tire Size 18.4-38, Units Are Off Of A John Deere 4440 Tractor, Year Is Unknown [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
