Re: The foot clutch does not work on my WD. Please help!
ACORANGE
07-04-2002 08:18:08
MAKE SURE THERE IS ENOUGH GEAR LUBE IN THE TRANSMISSION. MY 51WD DEVELOPED A GEAR LUBE LEAK AT THE PTO GASKET AND WOULD NOT SHIFT WELL UNTIL I PUT ENOUGH GEAR LUBE [USE 85-140 WT] IN THE TRANS. TO SLOW DOWN THE GEARS. GOOD LUCK WITH YOUR PROBLEM, HOPEFULLY YOUR CLUTCH ISN'T STUCK.
