Company Logo (800) 853-2651 Shop Now
Re: B Allis final drive fluid
Unimog
07-02-2002 20:30:00
Dave, my 41 B manual says summer 140 and winter
90, with a 1-1/2 pint capacity.
Now in a later AC B manual it says to use S.A.E.
20W at all times.
I think either will do the job, but I'm going with
the heavier lube in mine.
Hyperpack
07-03-2002 17:14:00
 Re: Re: B Allis final drive fluid in reply to Unimog, 07-02-2002 20:30:00
I spoke with an oil expert about this a couple years ago,He explained that the heavy EP oil was best for the gears while the lighter 20w oil was better for the bearings.I always use the heavy oil in gearboxes that are heavily loaded.Also non detergent or hydraulic oil has a slightly higher film strength than a detergent motor oil and does not absorb water but lets it settle out so it could be drained out periodically.
Bryan Smith
07-05-2002 12:49:19
 Re: Re: Re: B Allis final drive fluid in reply to Hyperpack, 07-03-2002 17:14:00
There's not a lot of difference in 20w engine oil and 80w gear oil *except* some extreme pressure additives. The viscosities are very similar - check out the website below for more info.
My CA's manual (original with the tractor in 1951) says 20w engine oil - that would be non-detergent engine oil. We've used 90w gear oil in the finals for all our AC's for years (30+) with no problems. Either way you should be fine.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: one 12.4X32 radial tractor tire on a john Deere 8 bolt rim. has some liquid within. Need to move its in my way as I do not have a JD to use such. Make me a good offer, and its yours. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
