Re: Looking For A Good Trick
Diesel Don
07-01-2002 21:10:10
My Dad and I used this trick on numerous occaisions-spray the h#$5 out of the bolts with a good penetetrating oil.WD40,PB Blaster,or Kroil,and leave them soak over nite.The next morning,get a bar of steel that about matches the OD of the head on the bolt.Hold the bar against the head of the bolt,get the biggest hammer you have,and give 'er a couple good raps.If the bolts aren't rounded off,get a six point socket on the bolt and work the bolt back and forth a couple times.If it doesn't loosen up right away,give it a couple more good raps and try the socket.If you can't get a socket to grip,try a Vise grip.I broke loose many stubborn bolts and nuts this way.A word of caution-I was doing this to get a stuck wheel off my buddy's car and missed the bar and hit myself in the knee with a 2 1/2# ball peen!I think I invented some new forms of foul language that day.
