Re: still CA problems
Bryan Smith
06-28-2002 08:54:41
Do you have a good fuel flow? If not remove the gas tank outlet/sediment bowl from the tank - sometimes rust flakes get down in there and restrict flow. After installing the inline filters did you clean the carb and flush the fuel line? that could help too.
We had a D14 that did this - turned out the carb float was set too low. We reset the float level to factory specs and it worked fine.
