Re: alternator and hydraulic seal replacement
Author |
Steve in N.J.
06-27-2002 13:36:25
Mike,First thing you want to do is a load test on the battery your using. This will identify whether the battery is good to start off with. When you pull a "draw" with a good draw tester, the needle shouldn't drop much, or at all if any. If it drops way down, it's battery time. Now, on 1 wire alternators, most 1 wires need 1000-1200 rpm's to excite the regulator for charging to start. Once the charging rate starts, it will charge till you shut off the tractor. (Charging rate should be between 13.9-14.5 14.2 is ideal)If you're using a voltmeter, a voltmeter hooks up differently than the OEM Ammeter. On the back of your voltmeter: the plus (+) to the battery or starter motor, and the ground (-) to the battery ground anchor bolt or battery grounding post itself. That's it! Also, it couldn't hurt to install an auxilary ground wire off the back of the alternator just to make sure the alternator has a good ground to the engine block. If you're using a 10SI style Delco Alternator, there is a threaded hole on the back to attach a ground wire. Good Luck, & have fun! Steve B.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
John Deere 143 Loader, good condition.
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
