Re: Stant will fit thermostat for WD45 OK?
Harold
06-21-2002 07:24:02
The rubber washer fits in back of the thermostat against the casting. And the thermostat fits inside that extra ring you get. Take the old one out and it kind of makes sense. I just replaced mine and I wondered about it till I got it apart. Hope this helps. Harold
Farmer Brown
06-22-2002 19:56:39
 Re: Re: Stant will fit thermostat for WD45 OK? in reply to Harold, 06-21-2002 07:24:02
Thanks. I haven't taken it apart, yet so hopefully it will make more sense when I see it, like you say.
Have you had any trouble with overheating ? The new one looks so small i wonder if will pass enough coolant to keep cool.
Harold
06-22-2002 21:50:07
 Re: Re: Re: Stant will fit thermostat for WD45 OK? in reply to Farmer Brown, 06-22-2002 19:56:39
No, mine runs about 180 to 190. Maybe yours is alittle out of time. Harold
Farmer Brown
06-23-2002 18:03:57
 Re: Re: Re: Re: Stant will fit thermostat for WD45 OK? in reply to Harold, 06-22-2002 21:50:07
Mine, doesn't heat up either, but I haven't put in the new thermostat yet. I was just concerned that it is too small and will restrict the flow.
