Re: WD45 Oil Lines
Greg(Mo)
06-21-2002 06:45:31
Yes, that is an oil line on top of the governor.
It gets fed right from the "T" fitting below the
dipstick.
Steve Slaughter
06-21-2002 07:39:27
 Re: Re: WD45 Oil Lines in reply to Greg(Mo), 06-21-2002 06:45:31
Thanks, Greg. Can you tell me where the line from the cylinder head goes, then? Mine goes from the T-fitting below the dipstick directly to the fitting in the head.
Greg(Mo)
06-21-2002 22:26:50
 Re: Re: Re: WD45 Oil Lines in reply to Steve Slaughter, 06-21-2002 07:39:27
did you get the sketch I sent you in email?
Steve Slaughter
06-22-2002 13:55:14
 Re: Re: Re: Re: WD45 Oil Lines in reply to Greg(Mo), 06-21-2002 22:26:50
Greg, I did get the sketch. Thanks for taking the time to help out. It was exactly what I needed. I still have to find an extra T-fitting. This morning I bought some 3/16" brake line and compression sleeves to make the additional oil line runs. Thanks again. Steve
Greg(Mo)
06-22-2002 20:50:29
 Re: Re: Re: Re: Re: WD45 Oil Lines in reply to Steve Slaughter, 06-22-2002 13:55:14
Glad I could help out. Any auto parts store should have the tee fitting...and I hope you meant 5/16"
line in your post (instead of 3/16") Have fun, those engines run good!
Greg(Mo)
06-23-2002 07:39:23
 Re: Re: Re: Re: Re: Re: WD45 Oil Lines in reply to Greg(Mo), 06-22-2002 20:50:29
Disregard that comment about 5/16 line....I must
have had a brain fart on that one. I thought it
was bigger tubing until I went out and looked again.
