Company Logo (800) 853-2651 Shop Now
Re: Leaking sleeve question
Craig MO
06-19-2002 19:06:06
Waterglass is still available at a pharmacy store. It is used in casts. Waterglass was mainly used to seal leaky head gaskets or small cracks in the head or block. The waterglass will not not seal sleeves as the sleeves vibrate when ignition occurs. Pull the sleeves and replace orings. Check sleeves for pitting if there is any replace them. Check block and sand with emery paper till smooth. Install new sleeves with oring assembly soap or pure vegetable oil. I would pull sleeves and forget trying to seal with some type of sealing compound.
Jim in michigan
06-20-2002 10:05:03
 Re: Re: Leaking sleeve question in reply to Craig MO, 06-19-2002 19:06:06
Thanks,,now does anyone know where I can get the o rings minus the sleeves? Jim
DanD.
06-20-2002 11:27:38
 Re: Re: Re: Leaking sleeve question in reply to Jim in michigan, 06-20-2002 10:05:03
Just go to your local AGCO dealer. If you don't know who that is, go to www.agcocorp.com and use their find dealer function.
