Company Logo (800) 853-2651 Shop Now
Re: D-14, bent push rods
Craig MO
06-15-2002 17:21:46
It could have gotten water in it at on time and stuck the valves and the pistons pushed them back up. They could have been adjusted wrong when the head was put back on. The valve seats may not have been grond to proper specs. when it was done. The adjusters on the rocker arms might have worked loose at on time partly bending them if they tightened up. It could be any number of things. I would put new push rods in and adjust valves and make sure rokers are oiling as this is another posibility that the rocker arms scored from lack of oil. See how you get along after resetting and replacing.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for 200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: John Deere Tires And Rims, (1) Set Of Duals, Axle Mounting Hubs, Tire Size 18.4-38, Units Are Off Of A John Deere 4440 Tractor, Year Is Unknown [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
