Re: D17 hydraulics/plowing
DanD.
06-13-2002 20:04:10
As to why it's not working on his tractors..Is he using mounted snap coupler plows?...won't work with pull type implements. Is he raising the traction booster lever to a level where the traction booster gauge points about straight up and down? Does he have the lift/lower lever positioned so that the tab stays locked in the lower hole on the quadrant? Needs to be there for the system to work. Check out allischalmers .com discussion board.
