Re: I brought home a B... now what?
Kiwi Pete
06-10-2002 23:49:23
I had a stuck engine on my 48 B and I found the easiest way is to take the head off and clean out the cylinders (any rust and crap) and then totally fill them with diesel and leave it for a while. if you can fill the engine better still as this will help free the crank if it is stuck (place it in 3rd gear and rock the back wheel every time you walk past it..but dont force it) and when it unsticks and it will, then you can take the pistons out and check the rings . mark the pistons 1-4 when you do remove them as the wear will be different in each sleeve and makes it easier when putting everything back together. A good idea is to remove the sleeves as well as more than likely the o-rings (at the base of the sleeves) will need replacing and you wont believe the crud that comes out of the water jacket area. if you can get a service manual this will be a great help. good luck
