Re: 48 AC-B
steve
06-05-2002 19:37:59
if you have the standard 6 volt battery with the original generator, then the wires go like this.
--"A" or "G" terminal on the gnerator goes to the cutout relay bolted to the generator
--other terminal of the cutout goes to the ampmeter then to the negative battery terminal
--F terminal on the generator goes to the light switch resistor.
--light switch must be grounded to work properly.
--if you want to test charging, short out the "F" terminal on the generator to ground, should get full charge, about 8 amps.
----- -if you have a 12 volt battery, then things have been changed form original.
Randall Hawk
06-09-2002 18:38:19
 Re: Re: 48 AC-B in reply to steve, 06-05-2002 19:37:59
Many thanks for the wiring diagram.Trouble is the cutoff is missing on the generator.Would this come wiyh generator if I had it rebuilt?
