Re: CA Hand Clutch Problems
Max(ia)
06-02-2002 17:02:47
I had almost $350 in parts. I had to replace with used parts, that means both axles, clutch assy and brake drum. The clutch facing and seals were new. Someone had bolted the clutch facings together, that held but the clutch housing had broken up. The brake drum had gotten into the drop housing, ruined the drum and ate out the keyway in the outer shaft. MY CLUTCH DIDN'T WORK EITHER lol. It's not to hard to work on if you have good tractor support and a way to handle the axle housing away from the tractor. Hope this helps Max
