Company Logo (800) 853-2651 Shop Now
Re: need help d-15 smoking bad
Dave Grubb
05-31-2002 11:17:03
Has any thing been done to the engine just before this started? Are the oil return paths from the head to the crank case open? Is the engine oil level too high/over filled(wrong dip stick)? You can have very good compression and have a problem with the oil rings. Are the oil control rings the 3 piece type? It is possible to assemble the oil control ring with the ends of the center piece of the ring overlapped. They have to be butted against each other. I am not sure on a D15 engine but is there supposed to be a baffle on the rocker arm shaft to control oil splash against the valve stems/guides? Is the crankcase venting system ok? Thats all I can think of at the moment. Keep us posted.
Latest Ad: Wanted 13x28 power adjust rim for D 17 allis in NE Nebraska [More Ads]
