Re: A carb fix you need to know about ...
kent
05-29-2002 13:16:29
thanks a bunch!! i'll bet this is what is wrong with my ca with a zenith. it's just like you described. won't idle right at all, governor doesn't work right and everything on the tractor is set right. i even rebuilt the carb and put new throttle bushings in the carb but to no avail. i never checked to see if the venturi was loose. we have a B with a MS carb and yes!!it does run sweet. i much prefer the MS carb because you can adjust the highspeed side. the Zenith doesn't have a high speed adjustment. i can hardly wait to try this. thanks very much.
