Re: Hydraulic fluid level
Ron
05-29-2002 04:39:42
Our WD-45's have never had anything other than 10w-30 motor oil in the hydrolics..... I see no reason to use anything else. The "other" oil check points are on the same side as the hydrolic dipstick.... One for the transmission, and a Larger one farther to the rear, for the rear end. I use 90 wt in the transmission, and also in the rear end... They should be full to the threads of the plug. Pretty common for these tractors to seep oil out at the rear of the engine, at the front of the hydrolic resevoir....the seal gets grooved. should be fine, tho. Remember---DON'T hook your thumbs in the steering wheel, on rough ground...!!!!! !! These ARE arm-breakers....!!!!!
