Company Logo (800) 853-2651 Shop Now
Re: Old Allis C Hydro's
Phil Aute3n (Tx
05-28-2002 12:45:23
Carl,
If the plow is bouncing off the ground, it isn't set up correctly. If this is an A-C plow, I would suggest you get a manual for it. This should tell/show you how to properly set it up so it works as it should.
Check the hydraulic fluid at the transmission fill plug. Oil should just run out when the transmission/differential/pump is full. The transmission/differential/pump holds 7 quarts. The filler plug should be a square headed plug on the side of the transmission about 16" behind the clutch pedal at the junction of the transmission case and the left hand axle. The original manuals specified SAE 20W non-detergent oil. This is important to prevent the foaming that detergent oil will cause. A good grade of hydraulic oil such as Agco 821 (I think that is the number) or I-H Hy-tran can be used, but in systems that are not in near 100% condition, they may not work as well. I can find 20W non-detergent oil and Traveller hydraulic fluid (an acceptable substitute for the Agco or I-H fluid) at my local Tractor Supply Co. (TSC) store.
Phil
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
Latest Ad: Need one ,castiron, screw-on hub cap. for a JI Case 8 foot grain drill [More Ads]
