Re: CA electricity
DanD.
05-27-2002 18:50:00
With an alternator you don't need the original light switch and you can use any simple switch that will fit in the box...can be obtained from any auto parts or hardware store. The magneto is a self contained unit that produces spark. It has basically a small generator and the coil, points, distributor, etc. to provide spark to the cylinders at the proper time. It requires no external power source except for the rotating shaft to turn it.
steve
05-28-2002 20:04:36
 Re: Re: CA electricity in reply to DanD., 05-27-2002 18:50:00
the alternator will recharge the battery as it is drained by the starter or the headlights. Dan has answered the rest.
Mike
06-11-2002 19:54:46
 Re: Re: Re: CA electricity in reply to steve, 05-28-2002 20:04:36
I decided just to use a $4 toggle switch instead of the $70 original
Thanks for the help
Mike
