Re: Allis `B` Miss
Kiwi Pete
05-20-2002 23:24:36
It sounds to me like the carby settings but I could be wrong- my 48 B had similar problems (if there is any black smoke when you throttle up then it could be too rich and will miss under load) I could not get it to run up a hill (under load) without missin and fartin...just keep tweaking the mixture and idle settings on the carb (the reccommended settings are in the manual if you have access to one.Make sure there is no air getting in around the exhaust manifold (sometimes they are not dead straight and need to be tightened - and if still loose add another gasket) and also between the carb and the air cleaner (the rubber hose needs to be clamped on tightly to reduce air being sucked into engine
good luck
