Company Logo (800) 853-2651 Shop Now
Re: Hand lapping valves-any pointers?
Howard
05-17-2002 05:16:07
I take the valves out and clean them with the wire brush the lap the in with a little grinding compound that you can fet at your auto parts store or you can mix up a paste with the dust from your bench grinder. I just use my little cordless drill to spin the valves, a little forward and a little back. clean up things real good when you get done.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: one 12.4X32 radial tractor tire on a john Deere 8 bolt rim. has some liquid within. Need to move its in my way as I do not have a JD to use such. Make me a good offer, and its yours. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
