Company Logo (800) 853-2651 Shop Now
Re: OIL SEAL FOR WD BELT PULLY
Tom
05-15-2002 16:25:11
Do you mean the seal where the belt pully seals into the casting, where it passes through the frame rail? I bought a length of seal from McMaster Carr for this, it was something like !7/32x 17/32" and while not as wide as the original, with the split at the top it is working. Have quite a bit left, anyone need some?
TED-N-ALLIS
05-16-2002 06:10:28
 Re: Re: OIL SEAL FOR WD BELT PULLY in reply to Tom, 05-15-2002 16:25:11
I found the cork gasket (The clutch housing
and frame rail) at AGCO in stock $7.00. The
length of gasket from Mcmaster is a great idea.
But I was impatient.Im looking for the oil seal
for the belt pully shaft.I now have the
dimentions so Ill see what I find today and
request a bearing and seal master catalog from the dist.
Thanks for all of the input.
Ted
Butch(OH)
05-16-2002 07:50:18
 Re: Re: Re: OIL SEAL FOR WD BELT PULLY in reply to TED-N-ALLIS, 05-16-2002 06:10:28
Oops, should have read yer post more carefully. I assumed you were looking for the shaft seal, not the housing seal.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: one 12.4X32 radial tractor tire on a john Deere 8 bolt rim. has some liquid within. Need to move its in my way as I do not have a JD to use such. Make me a good offer, and its yours. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
