Re: AC D17 SERIES IV Brakes
Craig MO
05-13-2002 17:03:31
The balls in your activators have probably gotten rusted. You will need to pull rear axle and remove the accuator. Pry the three springs off to seperate the two halves and remove the balls. If they are rusted or flat replace them. Take emery cloth and polish up the ramps on the accuators where the balls run. Also your brale disc might have stuck and seperated when they were applied. You can take the tin cover of the rear end housing to check the linings.
