Re: CA fuel tank gravity flow
gerald
05-11-2002 20:32:42
The hydrostatic gradient of water depending on its salinity is approximately 0.433 psi/ft. Since gas is lighter than water (ie: floats on water) its gradient is approximately 0.300 psi/ft depending on API gravity. Therefore if you have a full tank of gas and the top of the gas is 2' above the carburetor then the hydrostatic head at the carb is ( 0.300 psi/ft times 2' which equals 0.6 psi) Hope this helps.....
