Re: CA won't run
Stan Sewell
05-10-2002 04:55:27
All of the above are applicable...but, unless you have taken the carb apart and used a carb soak or spray can cleaner and fine wires to clear all passages...then blow all out with air...then do it again and re-assemble....must have a filter in line if the gas tank is cruddy....it will not maintain power enough to run...just did the same as you with an old farmall C...same carb I think.
Now it runs smooth and will take off on it's own power.
Stan
