Re: CA Spark Plugs
greg
05-03-2002 09:12:55
Brian, are you sure you didnt get 2 plug wires
crossed? check the firing order to be sure.
if that is correct, pull the plug you suspect to
be bad, and stick it in a different hole to see
if you have a defective plug. Make sure one of the
plug gaps didnt get closed up. good luck
