Re: One wire alternator
not charging
Steve in N.J.
05-01-2002 23:04:37
James,
One wire alternators work great, but they need around 1200-1400 rpm to "excite" the regulator. Once the charging rate starts, it'll charge till you shut down the tractor. Because tractors operate at lower rpm's it's a little tougher to rely on a one wire to keep a good charge in the battery unless you put the tractor to work for a while in order for the alternator to bring the reserve back into the battery. Short trips or low usage will eventually bring the battery's reserve down which will lead to a dead battery.
