Re: Checking out WC's
Brad Gyde
04-29-2002 19:51:42
I have 2 styled WC's... 1 parts, 1 to restore. All I will say is A GOOD BLOCK IS HARD TO FIND.
Also, these tractors don't have hydraulics (a very few of the last wc's did however) and some also did not have a pto.
If you plan to really use the tractor in farming, it don't have a lot of uses in a modern operation, but if you farm with older machinery (as I do) it can be a quite useful and a pretty good, reliable tractor overall.
Just My Opinions,
Brad
ff316
04-30-2002 13:12:57
 Re: Re: Checking out WC's in reply to Brad Gyde, 04-29-2002 19:51:42
Thanks for your input, Brad. I am looking for a tractor to restore. It probably will not be used, except maybe to plow a little for fun, and to pull a wagon now and then. Basically, a toy. I will be sure to check out the block, transmission, gas tank, radiator, and everything else before I buy. BTW, is there a really good WC website out there, similar to Farmall H.com or retiredtractors.com are for H's and JD B's? Thanks. Fireman
