Re: Front tire wobble HELP
brian
04-29-2002 15:55:14
if you pull the four bolts out of the front bolster(have the tractor jacked up and supported) there should be some shims between it and the tractor, try removing a shim and/or changing the thickness of the shim stack to allow more gear mesh. do not overdo it because the steering will not turn, BTDT. also check the drag link and the play at the steering box.
good luck.
steve
02-05-2004 06:38:06
 Re: Re: Front tire wobble HELP in reply to brian, 04-29-2002 15:55:14
I know this will seem silly, but if this has adjustable wide front end then first tighten the bolts which adjust the width of the front axle. Mine had play even after the front bearing where replaced. So I really tightened up the front adjustment bolts and the remaining play dissappeared.
