Re: WD shifting lever
JMS/MN
04-28-2002 21:09:39
The top plate, or tower, from a WD, will also fit, but you need to drill the second hole in the top of it- because the curved lever shifter uses two side pins as guides. Just set the tower in your drill press, and run the bit through the existing hole, through the other side, to make the hole for the second pin. Critical thing is to find a tower that is not worn too much for the ball of the shifter to fit in to.
