Re: AC-C Ignition problem
Duey (IA)
04-26-2002 18:12:18
Carl,
The rotor has to be timed to the points so when it is in the proper place, the spark is directed to the proper plug wire. If you have had it apart the drive gear has to be timed to the gear that turns the rotor. Duey
Carl
04-27-2002 17:20:58
 Re: Re: AC-C Ignition problem in reply to Duey (IA), 04-26-2002 18:12:18
Thanks Duey! Is there a simple trick to that? I know how to remove the rotor drive and move the cogs. Any helpful hints?
Carl
Duey (IA)
04-29-2002 18:14:46
 Re: Re: Re: AC-C Ignition problem in reply to Carl, 04-27-2002 17:20:58
Check your e-mail
