Company Logo (800) 853-2651 Shop Now
Re: Front tire size RC ?
Phil Auten (Tx)
04-17-2002 18:32:38
My '39 RC has Goodyear 5.00x15 "Triple Rib" on the front. The original size was 4.75x15 per my A-C data book, but I doubt if you can find them today. However, this may be an old size designation and be the same tire as a current 5.00x15. As for the type of tires, several brands (and probably several styles) were used during production. Originally an RC might have had Goodyears, Firestones, Goodriches or any one of several other brands depending upon who the current supplier was when the tractor was built. I would just go with a three rib type and not worry about the correct police. Check with Miller tire at the link below. They carry lots of old tread designs that are not readily available elsewhere. You just might find something you like!
My 2,
Phil
DPOST
04-18-2002 06:46:15
 Re: Re: Front tire size RC ? in reply to Phil Auten (Tx), 04-17-2002 18:32:38
Thanks for the good information Phill & Paul.
I think my main concern is getting the correct size. I think I will go with the 5-15 Firestones at TSC. That way I can pick them up on the way home from work and install them this weekend. These tires are a 3 rib desing that seems appropriate for the tractor.
As for correct police, keep them away form me. The rear tires are in good condition but are not the same brands. Other than that the tractor is in pretty much original codition except for an incorret starter switch, no battery box, an enlarged exhaust pipe hole in the hood to accomodate a muffler, and some appendage that someone welded to the axle housings. It also has spent the last 45 years outside so the paint looks a bit rough.
In another lifetime this tractor was part of our small farming opperation in MN. It and my dad retired to a 20 acre hobby farm in 1972 when the state took the farm for a freeway interchange. Since then the tractor has seen light duty as a wagon puller and has a buz saw attached to it for cutting fire wood. The goal is to get the tractor back to good enough working condition to allow the tean age daughters to use it to pull a harrow for preping their riding arena. I suppose this means that I also have to get the electrical system working again as well.
Thanks again, I probably will bug you with more questions as I gradually fix this tractor up.
D.D.Post
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Twin City Tractor. Prefer Model KTA on rubber. Restored or in restorable condition. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
