Re: My WD45 is stuck in 3rd gear...
Author |
Duey (IA)
04-13-2002 16:18:47
Pete, The shifter problem is probably due to wear in several places. You can access the problem by removing the rubber boot on the shift lever. Then remove the snap ring etc. and the lever can then be removed. You will now be able to look down on top of the shifting forks. With the shift lever or a long screw driver you can now move the shift fork back into neutral. Wear points are the groove on the "ball" of the shift lever, the square headed pin that rides in the groove, the ball itself, the socket, the tip of the lever and the top notch of the fork.Repairs will have to be determined by you after you have evaluated the wear points. You may only have to work on one or two things. If the shift lever twists around it would indicate a worn pin and groove. Over size pins were available at one time and the groove would have to be re cut to fit the oversize head or a new groove cut on the opposite side and a new pin put in the hole on the other side of the shift tower. The oversize pins also required the removal of the "soft plugs" in the side of the tower and the pin hole redrilled to the oversize shank of the oversize pin. Sometimes a big machine washer under the snap ring will help. The tip of the shift lever can also be built up with a welder and then reshaped. The same can be done with the forks but that will require the removal and disassembly of the shift tower. Duey
Pete
04-14-2002 06:42:59
Re: Re: My WD45 is stuck in 3rd gear... in reply to Duey (IA), 04-13-2002 16:18:47
Thanks for the help. I really appreciate you guys for helping me out on this one. Thanks again, Pete
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
Bumper - Ford Jubilee, Naa, 8N
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
