Re: WD 6VOLT TO A 12 VOLT SYSTEM
steve
04-12-2002 17:30:02
the 6 volt startere will work with 12 volts. if you have a magnito. it will be o.k. if you have a distributor you will need a 12 volt coil or a dropping resistor for the 6 volt coil. the simpliest way to install 12 volts, is to go to Auto Zone and buy a Delco alternator with an internal voltage regulator (1975 chevy truck). You will need to build or buy a bracket to mount it. The alternator can be purchased for $35-$40. Make sure the two terminals on the side are in line like this (- -) that means it is internal regulator. If it is (l l) like this, it is the old style prior to 1975 and needs an external voltage regulator like a generator. If you go ahead and get this far, ask again for a print on the wiring.
