Re: more wc help please
JMS/MN
04-11-2002 08:09:34
The front brackets are only for mounting the two-row cultivator. There are also two brackets that mount on the rear axles, near the fenders, to attach the cultivator frame to. The lift linkage is hooked to the power lift unit you once referred to as an over-running clutch. The radiator is held in place with two half inch diameter bolts accessed from underneath, inside the channel iron frame of the tractor, along with the 5/16 bolts on the hood. If your tractor is indeed a '37, unstyled, the electric starter is a bit unusual. Most of the unstyled WC's were hand-cranked.
