Re: Help. Charr-Lynn hyd. pump?
markp
04-09-2002 16:53:17
I don't know too much about the pump system on your tractor, but I would try this. If your tractor has two rams and you are having problems with one I would swap them out with each other to see if the problem migrates to the other side. if the problem stays on the same side see if you can change the lines into the three way valve. it should narrow down where the problem is.
