Re: Wobbling rear rim on a B?
Author |
steve
04-01-2002 20:04:44
Bryan, I took a steel plate and cut the oval hole with two flats in it with a torch, grind to fit good. then weld a big handle on it that you can slug with a sledge hammer. the problem is the hub slides onto a tapered splined shaft. as the splines wear a little, the hub comes loose. if you tighten the nut the hub moves in further than it was before. take the nut loose and clean threads. jack the tire up off the ground and then tighten the nut. see that the tire turns easily by hand. if the wheel gets tight as you tighten the nut, then the hub is bottoming out on the inside aginst the axle seal retainer because the tapered splines in the shaft are worn excessively. if this happens, remove the hub and grind 1/8 inch off the lip on back of the hub that is hitting the seal retainer and then reinstall the hub and tighten again, check easy to roll. of coures if the nut gets tight on the shaft and the hub is still loose, then you are right, you need to put a thicker washer on the shaft, under the nut. the washer should have a large enough center hole to slide freely
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
Bumper - Ford Jubilee, Naa, 8N
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
