Re: Wobbling rear rim on a B?
Steve in N.J.
04-01-2002 18:40:40
Bryan,
I have a 48 B and the rear nut that holds the center hub on only has two flat sides. At least on mine that's all it has. I put a giant pipe wrench with a long handle on mine to break it loose, (and a lot of tuggin')If I remember correctly, the nut loosened counterclock wise... When I reinstalled the nut, I neversiezed the threads so in case I ever have to remove it again, it should be a lot easier than the first time... Hope this helps. Steve
