Re: wd changing all lubercants
Tom
03-26-2002 16:56:01
There are 3 drain plugs for the transmission/rear end. Under the rear end, under the transmissio, under the pto housing or in the bottom of the pto if you have one. To totally drain the old fluid you need to remove all 3. Using both filler plugs will make filling faster and more complete. If you only use one the oil will have to run through ball bearings between compartments and may not come up to the level it should. Changing the final drive oil is a little more of a hasle, but you don't have to do it often and it is worth doing every few years. Keep the boot on the shift lever in new condition, water can get into the transmission through a cracked or missing boot, it will settle in the lowest point, the pot if you have one, freeze and crack the housing, after having messed up the bearings and gears maybe.
