Re: plow???
Rod (NH)
03-16-2002 20:24:03
Hi markp,
The B was designed to pull one single-bottom plow at a time. Standard plow arrangement for the B was 2-way mounted plows (no 3pt)...one bottom was right handed and the other was left handed for plowing a single furrow in each direction.
Standard disc harrows for the B (pull behind - no 3pt) were six feet wide in a four gang configuration...two gangs forward and two gangs to the rear. The B will pull this configuration nicely. They are, however, not intended to be raised with any type of lift mechanism.
Hope this helps you out.
Rod
markp
03-17-2002 04:46:45
 Re: Re: plow??? in reply to Rod (NH), 03-16-2002 20:24:03
Thanks for the help. i have a pull type harrow with two gangs now, but I want a three point type so I can turn around without tearing up the ground at the end runs. The hydralics are good and aftermarket so it will raise a small set just fine. thanks
