Company Logo (800) 853-2651 Shop Now
Re: 12V G conversion
Farmered
03-15-2002 06:10:34
I've done it with 3 Gs. Get a single wire alternator. It has the regulator built in and eliminates a lot of wiring problems.You will have to fabricate a new mounting bracket. While you are at it put a bolt terminal on the starter in place of the mechanical starter terminal. Then you can use a Ford 3 terminal type starter relay and a remote key type starter switch UP FRONT.
The alternator will run you about $70. You can use a garden tractor type battery. Good luck,Ed
Today's Featured Article - The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend. ... [Read Article]
Latest Ad: Bumper - Ford Jubilee, Naa, 8N [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
